17 years agoTiming violations on SignalTap II Analyzer
Hi, I am receiving lots of timing violations on signals crossing clock domains to SignalTap II Analyzer. Should I set false path to all the signals connected to the SignalTap II analyzer? ...
17 years agoYou need to treat signaltap as any logic inside the fpga for that is what it is.
The timing must not be violated or else your samples would be unreliable. You should use the same data clock (or a faster synchronised clock) to sample your data, so you don't need to cross from data domain to signaltap domain.
