10 years agoTiming requirements to a part of a circuit
Does anybody know how to set timing requirements to a part of a circuit? I mean there is a critical part of a circuit that needs frequency optimization, and it's not rational to apply frequency cons...
10 years agomax delay applies an absolute timing relationship, in nanoseconds between two nodes. It is NOT related to the clocks. If these are 2 registers and you already have clock constraints, then this max delay constraint is already infered at the clock delay. putting a max delay constraint of 2ns is like having a clock constraint of 500Mhz, so you are probably over-constraining the design.
This is NOT how you apply multicycle constraints.
