10 years agoTiming requirements to a part of a circuit
Does anybody know how to set timing requirements to a part of a circuit? I mean there is a critical part of a circuit that needs frequency optimization, and it's not rational to apply frequency cons...
10 years agoPlease could you clairfy? if your whole design is synchronous then you should just be able to set timing constraints to the clocks and it will do the work for you. Clock domain crossings need some consideration, but sometimes false paths are sufficient.
