17 years agoTiming Problem(Clock Edge)
Dear all, I'm new to VHDL and need all u guys out there, I'm currently designning a VHDL code for traffic light (two processes) coding style and i bump to this error regarding clock timi...
17 years agothanks for all ur comments. i hav finished modifying de traffic code and now it is really works.. sorry if i bother u all too much..
another question.. de prob that i facing now is that i want to generated a 1 Hz clock using clock divider method from the original crystal frequency of 33.333 MHz.. The FPGA board that I'm using is Apex20k EFC200-484 from Altera de code is as below : begin cloc:process(clk) variable cnt : integer range 0 to 16500000; begin if(clk'event and clk='1') then if(cnt=16500000)then cnt:=0; clkout<='1'; else cnt := cnt+1; clkout<='0'; end if; end if; end process cloc; I had compiled the code above.. and when i simulate for 2 seconds .. it took me overnite to finish .. anyone hav better idea than this method? thanks
