17 years agoTiming Problem(Clock Edge)
Dear all, I'm new to VHDL and need all u guys out there, I'm currently designning a VHDL code for traffic light (two processes) coding style and i bump to this error regarding clock timi...
17 years agoAlso I would look at the structure of your process. You have to be very strict with your coding style for synthesis:
process (clk, reset_n, async_load)
begin
if reset_n = '0' then
-- ansynchonous clear assignments
elsif async_load = '1' then
-- asynchronous load assignments
elsif rising_edge(clk) then
-- put your register assignments (i.e. your state machine) in here
end if;
end process Of course you don't have to have the asynchronous reset or load in there:
process (clk)
begin
end if;
end process Don't be tempted to add anything else into the rising_edge(clk) line as this will give you a gated clock. Altera have some guidelines on coding for synthesis (which are pretty much the same as other FPGA manufacturers): http://www.altera.com/literature/hb/...din g%20style (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=coding%20style) By the way the "clk'event and clk = '1'" notation that you've used is fine and basically the same as "rising_edge(clk)" - the only real difference is that the latter works with transitions like 'L' to 'H' in simulation - for synthesis it won't make a difference. I would start by tweaking your code to comply with this sort of standard and I'm sure you will get rid of the errors, a whole load more warnings that you haven't noticed yet and a whole load of nasties still waiting in the wings. Probably something like this:
process (CLK,RST)
begin
if RST = '1' then
state <= s0;
Digit1 <= (others=>'0');
Digit10 <= (others=>'0');
elsif CLK'event and CLK = '1' then
if pedestrian = '1' then
state <= s4;
else
case state is
when s0 =>
-- etc etc
end if;
end if;
end process Your pedestrian signal is now effectively a synchronous reset but note that the reset and clk conditions are as above. Hope this helps - the coding style document is really worth a read.
