11 years agotiming problem 1
timing problem 1
hi everyone: in my design, there is a pll to provide clk for outside sdram. my generate clk in sdc file create_generated_clock -name {SDRAM_CLK} -source [get_pins {inst2|altpll|sd1|pll7|clk[0]}] -master_clock {myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[0]} create_generated_clock -name {myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[0]} -source [get_pins {inst2|altpll|sd1|pll7|inclk[0]}] -duty_cycle 50.000 -multiply_by 4 -phase 288.000 -master_clock {EXT_CLK} [get_pins {inst2|altpll|sd1|pll7|clk[0]}] create_generated_clock -name {myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[1]} -source [get_pins {inst2|altpll|sd1|pll7|inclk[0]}] -duty_cycle 50.000 -multiply_by 4 -master_clock {EXT_CLK} [get_pins {inst2|altpll|sd1|pll7|clk[1]}] create_generated_clock -name {myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[2]} -source [get_pins {inst2|altpll|sd1|pll7|inclk[0]}] -duty_cycle 50.000 -multiply_by 2 -master_clock {EXT_CLK} [get_pins {inst2|altpll|sd1|pll7|clk[2]}] in order to constraint the output delay i do the follows:# **************************************************************# Set Maximum Delay# ************************************************************** set_max_delay -from [get_clocks {myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[0]}] -to [get_ports {sdram_clk0}] 3.000 # **************************************************************# Set Minimum Delay# ************************************************************** set_min_delay -from [get_clocks {myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[0]}] -to [get_ports {sdram_clk0}] 0.000 the from clk's name is strange because i use the derive_pll_clocks -use_tan_name. then the timing analyzer shows error, Registers to outputs error: http://www.alteraforum.com/forum/attachment.php?attachmentid=9506&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=9507&stc=1 i am so confused : 1.my contraint is the max and min delay from the output of the dll to the fpga output pin, why there are Register to Outpus (setup) and Register to Outpus (hold) error? 2.according to my generate clk : create_generated_clock -name {SDRAM_CLK} -source [get_pins {inst2|altpll|sd1|pll7|clk[0]}] -master_clock {myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[0]} so in the error report,the from clk :myqsys:inst2|myqsys_altpll:altpll|myqsys_altpll_altpll_99h2:sd1|wire_pll7_clk[0] and the to clk :SDRAM_CLK, i think the are one clk.1 Reply
keep asking for help...
