10 years agoTiming paths problem
hellow every body; I made a timing analysis using altera time-quest timing analyzer, and i found that there are many paths that is not belongs to my design and report a timing problems. Is this ca...
10 years ago --- Quote Start --- IP blocks often have required timing. You must specify timing constraints as needed by any IP you are using. You will find what is required (if anything) in the documentation for the IP blocks. --- Quote End --- Here's the best application note I've found on these things: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an545.pdf
