Timing paths from PORT_B_WRITE_ENABLE_REG to an inferred simple dual-port RAM output - why does this path exist?
You should instantiate RAM block through IP catalog. If using that , you would see what those options or parameters in GUI can be changed. Please see RTL below that I retrieved from generated dual-port RAM :
//Example of 8 bit width RAM
altsyncram altsyncram_component (
.address_a (address_a),
.address_b (address_b),
.clock0 (clock),
.data_a (data_a),
.data_b (data_b),
.wren_a (wren_a),
.wren_b (wren_b),
.q_a (sub_wire0),
.q_b (sub_wire1),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clock1 (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.eccstatus (),
.rden_a (1'b1),
.rden_b (1'b1));
defparam
altsyncram_component.address_reg_b = "CLOCK0",
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_input_b = "BYPASS",
altsyncram_component.clock_enable_output_a = "BYPASS",
altsyncram_component.clock_enable_output_b = "BYPASS",
altsyncram_component.indata_reg_b = "CLOCK0",
altsyncram_component.intended_device_family = "Cyclone V",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 32,
altsyncram_component.numwords_b = 32,
altsyncram_component.operation_mode = "BIDIR_DUAL_PORT",
altsyncram_component.outdata_aclr_a = "NONE",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_a = "CLOCK0",
altsyncram_component.outdata_reg_b = "CLOCK0",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.ram_block_type = "M10K",
altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE",
altsyncram_component.read_during_write_mode_port_a = "NEW_DATA_NO_NBE_READ",
altsyncram_component.read_during_write_mode_port_b = "NEW_DATA_NO_NBE_READ",
altsyncram_component.widthad_a = 5,
altsyncram_component.widthad_b = 5,
altsyncram_component.width_a = 8,
altsyncram_component.width_b = 8,
altsyncram_component.width_byteena_a = 1,
altsyncram_component.width_byteena_b = 1,
altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK0";
What clock frequency are you using for that RAM? Can put your inferred RAM here?
