JWils26
7 years agoTiming paths from PORT_B_WRITE_ENABLE_REG to an inferred simple dual-port RAM output - why does this path exist?
Targeting a Cyclone V SoC device, I have a lot of inferred RAM in my design. Most of them are simple single clock dual-port RAM. In the Timing Analysis there are paths from a PORT_B_WRITE_ENABLE_REG ...
GuaBin_N_Intel
Contributor
7 years ago@JWils26 You may be correct that it is tied to low since it is unused
- JWils267 years ago
So I guess I can cut those paths? It may help with timing throughout the design. I am concerned that when you try to locate the path in the Technology Map Viewer, it highlights the data output path, which obviously I don't want to cut!
