Timing issues on DFF feedback loop.
Could you provide a simple test case and testbench to reproduce the behavior?
KhaiY
Its a large design and the test vectors are applied on top level IOs. I present the portion of schematic where I have narrowed down and found the error to be originating.
The point of interest is DFF44. Whose output is X (unknown) right from the beginning of the simulation.
CONTCLK_IN: Is the input to DFF44 and sync block.
QCLK_IN: Is the input to DFF106
Sync block is just 2 DFF synchroniser. Circuit below:
Please have a look at the simulation output. The 'X' (unknown) has propagated to sync block and later the output of OR60 block is also X. I have attached the simulation outpt for better resolution. CTEST, CLEARN and Clock inputs are all in the simulation window.
Thank you!
