15 years agotiming constraints for EHPI DSP to FPGA asynchronous interface
Hi, I am trying to write timing constraints for connecting a TI DSP, TMS320VC5510A, to a Cyclone IV FPGA. The bus used is EHPI in Multiplexed mode. It looks confusing because the interface is asynchr...
15 years agoHi Rysc, Thanks again for your brilliant help :)
I see what you mean about my generated clock error ( although i didnt quite get what you meant about a space in the name ?)...i see i have missed off the get_registers / get_ports commands). In the design the REG hds_ni is driven from the PLL clock output : EHPI_PLL_inst|altpll_component|auto_generated|pll1|clk[0] The output pin is : hds_n, which is fed by the REG output. hds_ni ...so now i have created the following constaints : # Create Generated Clock for STROBE from PLL driving REG create_generated_clock -name HAD_STROBE_REG -source EHPI_PLL_inst|altpll_component|auto_generated|pll1|clk[0] [get_registers hds_ni]# Create Generated Clock for STROBE to output pin create_generated_clock -name HAD_STROBE -source HAD_STROBE_REG [get_ports hds_n] Does this look remotley correct ? When i run your report commands though i still get zero setup and hold paths for these paths. many thanks
