14 years agoTiming Closure issue in Stratix V
Device: 5SGSMD8K3F40I3 My design consists of niosii core with one ITCM (32 Kbytes) and one DTCM (16 Kbytes). Its difficult to close timings for the design. The reference clock is 245 MHz. The...
14 years agoIf your system is in SOPC, you might try adding pipeline bridges into your design. Other than that, you may try running some of the parts at a slower rate and using a clock crossing bridge. (245MHz does seem a bit fast)
I have not worked with Q-Sys at all, so I don't know if the design flow uses the same blocks.
