Timing analysis error on Asynchronous control signals
I think as long as you are using edges instead of logic levels for these control signals, the tool will still look at these as clocks.
Is there a reason why you must do this and can't just turn these processes into combinatorial logic instead of registers?
- NShan124 years ago
This is a legacy design and I am using the same.
I anyways gave a try by changing the code as below:
PROCESS ( ale, adbus )
BEGIN
IF ( ale = '1' ) THEN
address <= adbus;
END IF ;
END PROCESS;PROCESS ( wrn, clearn, adbus )
BEGIN
IF clearn = '0' THEN
data<= "0000000000000000" ;
ELSIF ( wrn = '0' ) THEN
data <= adbus( 15 DOWNTO 0 );
END IF ;END PROCESS
Surprisingly, timing analyzer still shows that the clocks ALE and WRN are unconstrained.
I see in the RTL viewer that ALE and WRN are used as the latch enable signals which concurs with the code above. I do not understand why the timing analyzer still complains that these are unconstrained clocks.
Is it critical to proceed with these timing errors? Can I go back to existing legacy solution where edges of ALE and WRN are used?
In any case, how can I solve the unconstrained clock warning by the timing analyzer?
Thank you very much!
