10 years agoTiming analysis error: Modelsim error vsim-3039
I have an 8b counter for learning timing analysis. I have completed Fitter, Assember, Timequest and EDA Netlist without any error. I have added the sdc file to the Assignment. When I run the gate lev...
10 years agoThe timing netlist will be output from the compiler. And is probably in a different language to the test bench. Hence the problem.
Honestly - if you did good design practice and it meets your timing requirements, its probably quicker just to load the design on the chip and see if it works than run a timing simulation (11 years in the industry - ive never had to run a single timing simulation)
