17 years agoTimeQuest with Stratix III to Stratix III I/F
I'm new to using TimeQuest and I can see how to constrain an interface to an external device with know clock to output, setup and hold time specifications. I'm trying to send data serially bet...
17 years agoFanning a single clock is easiest, but forces lower clock rates. Since you're registering your inputs and outputs(and most likely I/O registers get used, which will happen automatically due to your timing constraints), the output timing of an FPGA should not be affected by the input timing, or vice-versa. My feeling is that you should be able to do this without going source-synchronous, but I don't know all the details. (I would recomend using a PLL).
