14 years agoTimeQuest Constraint on PLL
I have a fairly trivial .sdc file which works with the following code: # Constrain the external FPGA clock from oscillator create_clock -period 20 -name clk [get_ports CLK]# Derive pll clocks ...
14 years agoIf they're independent files, then you're missing the create_clock. The generate clock has to be based off another clock.
Assuming it's some of both, copy out of the TimeQuest messages from your derive_pll_clocks that worked. Derive_pll_clocks is not a real .sdc constraint, but a script that runs other .sdc commands. It tells you exactly what it ran, so if it worked, copy and paste from that. Besides the space in auto(which I assume is a cut and paste issue, as I've seen that here), you seem to be matching name conventions. You can either do entity:instance or just instance, i.e.: Upll:pll50_lock|altpll:altpll_component|PLL50_LOCK_altpll:aut o_generated|pll1|inclk[0] or pll50_lock|altpll_component|au o_generated|pll1|inclk[0] But in yours, it's using only entity on the top-instance and the PLL1 instance. Again, start with what derive_pll_clocks does.
