17 years agoTimequest and PLL jitter
Hi, is it necessary to specify any timing jitter when using PLL outputs in an SDC file i.e. as well as the derive_pll_clocks command? Is there anything else I need to do to make sure I'm covering...
17 years ago --- Quote Start --- I'm getting some wierd results on Stratix III even though my timing analysis is reporting positive setup and hold slack. I've done what I believe to be a pretty thorough job of specifying the timing constraints but I'm beginning to wonder if I've missed anything. --- Quote End --- Even though you were careful, review these reports if you haven't already:
- Report Ignored Constraints
- Report Unconstrained Paths
- Check Timing
- Design Assistant
