15 years ago
time in generic clause of entity for synthesis
Dear All,
is it possible to use generic of type 'time' in an entity declaration which is used for synthesis? I'd like to use time specification as top-entity generic parameter, which is in the sub-entity recalculated to integer and hence it is fully synthesizable (recalculation using e.g. 100 ns / 25 ns leads to integer right?).
This works great in simulation, however quartus refuses to instantiate block claiming that 's' does not exist:
entity top_entity is
generic (
DELAY_LINE_DEPTH : integer := 8; --! default FIFO used for BLR
RESET_PULSE_LENGTH : integer := 50; --! length of automatically generated reset
BCF_DEFAULT_THRESHOLD_VALUE : integer := 3700; --! default value of threshold loaded when register is reset
MAX6627_AUTORUN : time := 2s); --! autorun of max circuit
    According to my STANDARD library, the name of the second unit is 'sec' and not 's'... even if all the other units are 'ms' 'us' 'ns' etc...
    So it seems that Modelsim is doing more than the standard.
    Confirmed. 1sec works in Q9.1, so modelsim extends the standard behaviour
    thanks for clarification
    d.
