12 years agoThis is kind weird...
I have 4 signals (analog) from DC-DC Buck Converter. FPGA is supposed to generate pwm signal out. But the weird thing is that. If 2 of signals from analog come the same time, then break pwm output. If there are not a the same time, then it's ok.
I have all modules run independent each other.... wire wEnable; Filter FilterEnable (.clk(c0_100Mhz), .iSignal(iEnable), .oSignal(wEnable)); wire wfRef, wRef; Filter FilterRef (.clk(c0_100Mhz), .iSignal(iRef), .oSignal(wfRef)); createRef createRef (.clk(c0_100Mhz), .iRef(wfRef), .iSync(wiSync1), .out(wRef)); // ------ Group 1 ----- wire wSync1, wPwm1, wiSync1; Filter FilterSync_1 (.clk(c0_100Mhz), .iSignal(iSync[0]), .oSignal(wiSync1)); sync2pulse neg2pulse_1 (.clk(c0_100Mhz), .in(wiSync1), .out(wSync1)); SyncPwm PWM_1 (.clk(c0_100Mhz), .iEnable(wEnable), .iRef(wRef), .iSync(wSync1), .oPwm(wPwm1)); pwm2pulse pos2pulse_1 (.clk(c0_100Mhz), .in(wPwm1), .out(oPwmH[0])); // ------ Group 2 ----- wire wSync2, wPwm2, wiSync2; Filter FilterSync_2 (.clk(c0_100Mhz), .iSignal(iSync[1]), .oSignal(wiSync2)); sync2pulse neg2pulse_2 (.clk(c0_100Mhz), .in(wiSync2), .out(wSync2)); SyncPwm PWM_2 (.clk(c0_100Mhz), .iEnable(wEnable), .iRef(wRef), .iSync(wSync2), .oPwm(wPwm2)); pwm2pulse pos2pulse_2 (.clk(c0_100Mhz), .in(wPwm2), .out(oPwmH[1])); Best, SeanNo RepliesBe the first to reply
