lance9
2 years agoThere is an error in selecting GXT channel
In the L-Tile/H-Tile Transcever Native PHY Intel Stratix 10FPGA IP , set the VCCR_GXB and VCCT_GXB supply voltage for the transceiver to 1_1V, select GXT for transceiver channel type ,select Basic(E...
Kshitij_Intel
2 years agoHi,
Please refer the Specs.
2.3.2. GXT Channels (intel.com)
It seems your data rate is out of range for GXT Channels.
Thank you,
Kshitij Goel
lance9
2 years agoThank you for your reply.
If I set Data rate to 18000Mbs I will get the following error:
