The written code works fine, but the behavior is wrong.
I still don't understand.
I wrote a 4-bit counter asynchronously, and it was written to reset all 4 bits at the same time, but I don't understand whether bit0, 1, 3 become "0" and bit2 becomes "1".
After I uploaded a question to https://community.intel.com/
The programming seems to be complete, but the board does nothing.
Can you understand why this MAX10_10M02SCU169 board is not working?
I haven't made any progress since then. ^^
Because my MAX10_10M02SCU169 board is broken.......
I'm sorry I couldn't give you good news.
Regards.
You may use ModelSim to create testbench and observe the output signals. I have tried to create a testbench for it but there was no result. This is because the output was not the 7-segment display. I have tried to run another similar example from https://www.fpga4student.com/2017/09/seven-segment-led-display-controller-basys3-fpga.html , the output was the 7-segment display so I'm able to observe the output signals.
Ean
