OJin0's avatar
OJin0
4 years ago
The written code works fine, but the behavior is wrong.
This is the code for the clock that displays minutes/seconds, and attaches the project folder.
The written code works fine, but the first digit of the second position becomes '4' upon reset.
That is, 04,05,06,07,08,09 -> 10,11,12,13,14,15,16,17,18,19 -> 20,21,22,23, was expected.
The problem works as 14,15,16,17,18,19 -> 24,25,26,27,28,29 -> 34,35....
I have a question.
There is nothing wrong with the code in the Verilog HDL editor,
Is there a place where I write code that can affect the behavior in other areas that are not visible to me?
For example,
Is there a place to write scripts?
Is there a place to write the header file?
Is it possible to insert hidden characters in the editor?
I wonder if code can be injected during compilation, etc.?
If possible, what can I do to prevent this problem?
Because, I feel like someone is tampering with my PC's Quartus from a remote location.
thank you.
Quartus 20.1.1 (image attached)
FPGA: M10, 10M08SCU169, 50MHz Clock
BOARD: QMTECH_MAX10_10M08SCU169
Coding Purpose: For Minute/Second Clock
Peripheral: 74HC595 Built-in 7-segment LED (with schematic image attached)
  • YEan's avatar
    YEan
    We do not receive any response from you to the previous question that have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Ean
  • OJin0's avatar
    OJin0
    I still don't understand.
    I wrote a 4-bit counter asynchronously, and it was written to reset all 4 bits at the same time, but I don't understand whether bit0, 1, 3 become "0" and bit2 becomes "1".
    After I uploaded a question to https://community.intel.com/t5/Programmable-Devices and programmed with my MAX10_10M02SCU169 board, the board is not working.
    The programming seems to be complete, but the board does nothing.
    Can you understand why this MAX10_10M02SCU169 board is not working?
    I haven't made any progress since then. ^^
    Because my MAX10_10M02SCU169 board is broken.......
    I'm sorry I couldn't give you good news.
    Regards.
  • YEan's avatar
    YEan
    Do you have any update on your problem?
    Ean
  • OJin0's avatar
    OJin0
    The designed 4-digit 7-segments were coded for 24 hours and 60 minutes.
    Currently attached coding is counted up in 1 second cycle for testing.
    • YEan's avatar
      YEan
      What do you mean by " first digit of the second position becomes '4' upon reset".
      Ean
