14 years agothe waitrequest of avalon
Hi: the output shoud use the register many paper write that,but I find that if the waitrequest output with register will lead to delay a cycle.it is difficult to design the register timing.if us...
14 years ago --- Quote Start --- The fast and slow classification referred to how fast a component can deliver data to the Avalon interface, and how to implement the waitrequest control for both styles. You point out a slight variation, so I'll address that. --- Quote End --- As I already pointed out, your classification into 'fast' and 'slow' is not relevant at all in implementing the logic for wait request. Wait request is asserted under the following conditions: - Input interface (i.e. responds to 'write'): Set active when the slave is not able to receive any more input. - Output interface (i.e. responds to 'write'): Set active when the slave is not able to produce any more output. End of story. --- Quote Start --- The implementation detail that requires separation into these two classifications is that the device should have both input and output registers. These registers are there to cut the timing path between the fabric and your custom component. --- Quote End --- These input and output registers can be there in either a 'fast' or 'slow' device. They are totally irrelevant to wait request, they do not alter the fundamental definition of when wait request should be asserted as mentioned above. --- Quote Start --- 1) Slow devices. The input registers on the read/write controls delay those signals into the component by one clock. If waitrequest was deasserted, then the component would have already accepted one transaction. Given that the component waitrequest output is also registered, then by the time it asserts the response handshake, it may have had to accept two transactions. By starting out with waitrequest active, the control FSM can deassert the control for a single clock, and then process the transaction. --- Quote End --- You're describing the operation of a one deep FIFO and calling them 'input registers'...I don't think you realize that, but you are. --- Quote Start --- 2) Fast devices. A fast device such as a RAM, registers, or an interface with a FIFO can generally start with waitrequest deasserted. RAM or registers can handle writes on every clock, and deliver data after a pipeline delay, so their waitrequest signals can generally remain low. During reset, their waitrequest should be asserted (per the Avalon specification recommendations). --- Quote End --- Not relevant...see previous definition of the implementation logic for wait request. --- Quote Start --- FIFO devices need to make use of their almost-full flags when determining the state of waitrequest. --- Quote End --- FIFOs do not need to make use of the almost-full (or almost empty) when determining the state of wait request. Full and empty represent wait request directly, no 'almost' required. Try it and see. The only reason one would have for using 'almost' flags is so that one could take those flags and delay them by a clock cycle to set wait request. By doing so though you show that you've missed the point that the flags already are the outputs of a flip flop and can be used directly. --- Quote Start --- If there have been no transactions for a while, and the transaction FIFO has drained, then waitrequest can be deasserted. --- Quote End --- Yes...FIFO full will not be set, wait request = FIFO Full therefore wait request will not be set...no logic is needed in between FIFO Full and wait request. --- Quote Start --- For example, a write-burst can occur on the Avalon bus and be write-posted to the FIFO. Those transactions can then drain from the FIFO to the external device, eg. an SRAM, at a slower rate. If another write or read transaction occurs on the Avalon bus before the FIFO has been drained, then the control FSM can either leave waitrequest asserted until it is completely finished with the previous transaction, or it can use the FIFO almost-full flag to determine whether to accept more transactions into the FIFO. --- Quote End --- You can choose to overcomplicate the logic for wait request as much as you'd like...just so long as you don't undercomplicate it and accept a command that you can't process. Kevin Jennings
