13 years agoThe virtual clock about input or output in timing constrain
When we do timing constrain in input or output, usually we need create a virtual clock. My question is, how can I know the phase relation between virtual clock and clock inside the system, in order t...
13 years ago --- Quote Start --- Let's also say the board oscillator takes 1ns longer to drive the external device. --- Quote End --- That is what I asked. My question is: 1. how can I know in which case, the board oscillator will takes a duration (e.g. 1ns) to drive the external device? 2. Can this duration be controlled by PCB designer? 3. Where can I check it if I have a PCB? Thanks very much.
