13 years agoThe virtual clock about input or output in timing constrain
When we do timing constrain in input or output, usually we need create a virtual clock. My question is, how can I know the phase relation between virtual clock and clock inside the system, in order t...
13 years agoPossibly. Let's say clk1 drives some external device and clk2 drives the FPGA, and external device drives the FPGA. Let's also say the board oscillator takes 1ns longer to drive the external device. Also say the external device has a Tco of 4.7 and min Tco of 2.4, and drives onto ports din[*] of the FPGA. You might do something like:
create_clock -period 10.0 -waveform {1.0 6.0} -name ext_clk create_clock -period 10.0 -name fpga_sys_clk [get_ports fpga_sys_clk] set_output_delay -clock ext_clk -max 4.7 [get_ports {din[*]}] set_output_delay -clock ext_clk -min 2.4 [get_ports {din[*]}]
