14 years ago
the quarter sine LUT code
Dear all
I need to get the quarter sine LUT in DDFS (Herewith the MATLAB code that I used)
i=[0:i-1];
x= (i-1)*sin ((pi/2)*i/31));
    There is some error in your sine values but almost correct.
    Try this:
    x = round(255*sin(2*pi*(0:1023)/1024));
    x = x(1:256);
    You should get proper quarter sine from x otherwise tell us what you do with x.
    you can also just use:
    x = round(255*sin(2*pi*(0:255)/1024));
    The Quarter sine wave LUT code for 8 bits:
    i=[0:255];
    x= 255*sin ((pi/2) *i /255);
    y=str(x,8) ;
    but when i used it in DDS simulation , I got no sine wave((note: i applied all the other requirment))
    As far as i know MATLAB uses floating point representation, which is not implemented in HDL by default. Maybe if you give more information (LUT input,output width, precision, what language you use) I could help you out.
    According to this equation :
    i=[0:i-1];
    x= (i-1)*sin ((pi/2)*i/i-1)+ 1/2*(i-1));
    The result that I got is not the sine wave shape (the LUT values inverted in minus when it pass the half of (pi/2) range ). herewith the attached sine wave file
    --- Quote Start ---
    --- Quote End ---
    Hope you got it :)
    What exactly the question is?
