17 years agoThe Nios II Error
When I build the helloworld,an error occured:
Compiling hello_world.c... Linking hello_world_0.elf... /cygdrive/d/altera/80/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region onchip_mem is full (hello_world_0.elf section .text). Region needs to be 37260 bytes larger. /cygdrive/d/altera/80/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region onchip_mem is full (hello_world_0.elf section .bss). Region needs to be 320 bytes larger. /cygdrive/d/altera/80/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: address 0x4140 of hello_world_0.elf section .onchip_mem is not within region onchip_mem /cygdrive/d/altera/80/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rodata [00002020 -> 000024ff] overlaps section .exceptions [00002020 -> 000021c7] /cygdrive/d/altera/80/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rwdata [00002500 -> 00003f2b] overlaps section .text [000021c8 -> 0000d18b] /cygdrive/d/altera/80/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .bss [00003f2c -> 0000413f] overlaps section .text [000021c8 -> 0000d18b] collect2: ld returned 1 exit status make: *** [hello_world_0.elf] Error 1 The onchipmem is 8kBytes,and the cpu is standard.Who can tell me what's the meaning above?1 Reply
Your on-chip memory is too small. It looks like you'll need 64K. Make your on-chip memory bigger, or try to shrink the size of your code (use smallc library, etc.)
