17 years agoThe Good Led
Hey guys,
I'm new to Quartus II and my Cyclone II. So I have just a question that is probably very simple. For one I was reading in the quick start guide and it said that when i power on the board that the blue led and the good led should light up, as well as the lcd and what not. but when i turn mine on i just get the power light, nothing else. What am i doing wrong? Any help would be greatly appreciated. Thanks, Cory1 Reply
You are apparently talking of a particular Dev Kit, it would be helpful to know the type. The behaviour described in the quickstart manual depends on a factory default configuration loaded at startup. It may be necessary to set certain configuration switches or jumpers also to enable this configuration, the quickstart manual should tell how. It may be also the case, that the factory default configuration has been overwritten, then the quickstart or user manual tell in detail how to restore it.
