The configuration issues of Cyclone 10 GX
- 1 year ago
Hi there,
1. The size of the flash memory you choose is generally correlated with the amount of logic resources you use. The more resources you utilize, the larger the resulting binary file will be. My recommendation is to determine the final flash size after compiling all functionalities and generating the RPD file. However, you can also refer to Table 54 in the datasheet as a reference.
https://www.intel.com/content/www/us/en/docs/programmable/683828/current/configuration-files.html
2. The flash model you mentioned has not been verified on our side, so we cannot guarantee its compatibility. I recommend selecting a flash model from the list provided in the link for reference. Table 4.
WZ
Hi there,
WZ
