14 years agoThe config problem on EP3C10 with EPCS4
Hi, all I have encountered a trouble in the configuration of EC3C10 by AS mode with EPCS4. The PCB board was used normally and FPGA can be config successful ago. But i am confuse...
14 years agoHow do you program and check the EPCS? If you can use a SFL image then you can access the EPCS through the FPGA's pins and check that they are connected properly.
Did you check the DATA signal between the EPCS and the FPGA with a scope too?
