14 years agotestbench integer type
Dear all,
Below is my testbench code that i simulate in ModelSim. --------------------------------------------------------------------- library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_Std.all; entity reg_tb is end; architecture bench of reg_tb is component reg PORT ( input : IN integer RANGE -127 TO 127; clk : IN bit; output : OUT integer RANGE -127 TO 127 ); end component; signal input: integer RANGE -127 TO 127; signal clk: bit; signal output: integer RANGE -127 TO 127 ; constant clock_period: time := 10 ns; signal stop_the_clock: boolean; begin uut: reg port map ( input => input, clk => clk, output => output ); stimulus: process begin -- Put initialisation code here input <= "3"; clk <= "0"; wait for 100ns; input <= "12"; clk <= "1"; wait for 100ns; stop_the_clock <= true; wait; end process; clocking: process begin while not stop_the_clock loop clk <= '0', '1' after clock_period / 2; wait for clock_period; end loop; wait; end process; end; This is the error: Error (10515): VHDL type mismatch error at reg_tb.vhd(35): integer type does not match string literal Can anyone tell me, where I'm wrong..Many thanks
