16 years agoTEMPDIODE reading low
I'm reading the temp diode on a stratix IV fpga, and it reading about 50C below what it should be. It is changing in regards to thermal heat and cooling, but it always seems about 50C too low....
16 years agoWhat value are you reading from the sensor (Digital value)? Are you using the internal ADC or an external ADC. If external, which sensor are you using?
Jake
