8 years ago[TCL] query_collection -> why not working?
Hi All,
I'm working on the following example: https://www.altera.com/support/support-resources/design-examples/design-software/tcl/all_virtual_pins.html Here is the script:load_package flow
proc make_all_pins_virtual {} { execute_module -tool map set name_ids foreach_in_collection name_id $name_ids { set pin_name post_message "Making VIRTUAL_PIN assignment to $pin_name" set_instance_assignment -to $pin_name -name VIRTUAL_PIN ON } export_assignments } The script itself works without problems. But, when I try to list as the contents of the created collection using the query_collection command, I receive the following error message: > query_collection Error:ERROR: Quartus Prime Tcl command "query_collection" is only available for use in the following executables: Error: quartus_fit Error: quartus_sta Error: while executing Error:"query_collection _collection0" Why? What's the problem? How can I list the created collection of the pins? Thank you!
1 Reply
Any response? Any help?
