15 years agoSystem Verilog for Carry Save Array Multiplier (Proble!!!)
hi,
I was trying to design a 4x4 carry save array multiplier, i use a system verilog code to infer the full adders array, there were no code errors and i used the RTL view to verify the connections, everything looks fine, but i got weird results (e.g. 3x1 = 15; 7 *1 = 17 !!! ) :confused:... my aim is to make the code expandable to any bit width:(... can any give advise???? ---------------------------------------------------------------------------------------------------------- //Carry_Save_Array_Mult0.sv module Carry_Save_Array_Mult0( a, b, p ); parameter DATA_WIDTH = 4; input [(DATA_WIDTH - 1):0]a; input [(DATA_WIDTH - 1):0]b; output [((DATA_WIDTH*2) - 1):0]p; // the product wire s[(DATA_WIDTH - 1):0][(DATA_WIDTH - 1):0]; // partial product array wire ci1[(DATA_WIDTH - 1):0][(DATA_WIDTH - 1):0]; // carry_in wires array wire co1[(DATA_WIDTH - 1):0][(DATA_WIDTH - 1):0]; // carry_out wires array wire [3:0]w0 = ({a[0],a[0],a[0],a[0]})&(b[3:0]); wire [3:0]w1 = ({a[1],a[1],a[1],a[1]})&(b[3:0]); /*********************************************************************************************************/ //this process is used to generate the first row of the multiplier genvar i; generate for(i = 0; i < DATA_WIDTH ; i++) begin: first_row FULL_ADDER fa_r0( // call the full_adder module .x(w0[i+1]), .y(w1),.ci(co1[0][i-1]),
.co(co1[0]), .p(s[0][i]) ); end endgenerate /**********************************************************************************************/ // this process is used to generate the rest of the rows by instantiating the full adders genvar j, k; generate for(k = 1; k < (DATA_WIDTH - 1) ; k++) begin: rest for(j = 0; j < DATA_WIDTH ; j++) begin: of_the_rows if(j < (DATA_WIDTH - 1)) begin FULL_ADDER fa_r1( // call the full_adder module .x(a[k+1]&b[j]), .y(s[k-1][j]), .ci(co1[k][j-1]), .co(co1[k][j]), .p(s[k][j]) ); end else begin FULL_ADDER fa_r1( .x(a[k+1]&b[j]), .y(co1[k-1][j]), .ci(co1[k][j-1]), .co(co1[k][j]), .p(s[k][j]) ); end end // first for loop end // second for loop endgenerate wire p0 = a[0]&b[0]; // bit[0] of the result assign p = {co1[2][3],s[2][3],s[2][2],s[2][1],s[2][0],s[1][0],s[0][0],p0}; // result[7:1] endmodule ----------------------------------------------------------------------------------------------------------- //FULL_ADDER.v module FULL_ADDER( x, y, ci, co, p ); input x, y, ci; output co, p; wire a = x^y; wire b = x&y; wire c = ci&a; assign p = ci^a; assign co = b|c; endmodule ------------------------------------------------------------------------------------------------ Regards.
