14 years agosystem on chip
Hi, someone could help me? I designed the nioss with sopcbuilder, code with eclipse, hardware ad-hoc with Quartus. Now how can I simulate it all together? I tried to add my vhdl cod...
14 years ago --- Quote Start --- I tried to add my vhdl code, in the code created by sopcBuilder, where it says: "<ALTERA_NOTE> INSERTED BETWEEN CODE HERE and add your component signal declaration here" but then ModelSim says: # ** Warning: (VSIM-3473) Component instance "componente_trasmissione: top_component_comunicatore" is not bound. why not bound? What's wrong? thanks very much. --- Quote End --- It means that there was no architecture found for the entity called 'top_component_comunicatore'. Find the VHDL file that contains the architecture and include it into the Modelsim project. Kevin Jennings
