14 years agosystem-console missing procedure
I am trying to use system-console on a windows XP 32-bit system. The messages at startup are: Finished initialization C:\altera\11.0\quartus\sopc_builder\model\lib\JtagJNI.dll: The specified ...
14 years ago1. Can you use jtagconfig?? << this will confirm that you have right path to quaruts
2. Does the path match with "quaruts_rootdir" ?? set to Q11.0 path? 3. Can you use java? what is the version? << the jtagjni is for java 4. try opening system-console from nios2-command prompt
