14 years agosystem-console missing procedure
I am trying to use system-console on a windows XP 32-bit system. The messages at startup are: Finished initialization C:\altera\11.0\quartus\sopc_builder\model\lib\JtagJNI.dll: The specified ...
14 years agoJtagJNI.dll is used for all communications over JTAG so if SystemConsole can't find it you won't get much done I'm afraid.
Are your paths set up right? Windows uses the PATH variable to locate dlls - the setup program should have got that right. SystemConsole has given you the full path to JtagJNI.dll so it must have found that - my suspicion is that one of the DLLs which JtagJNI.dll uses can't be found. In 11.0 these are in the quartus/bin directory so please check that's on your path.
