14 years agoSynthesis timing issues
Hi, Whenever the timing requirements are so high, it often happens that the removal of logic further decreases the fmax. For example in a project I need 400Mhz to achieve and somehow fmax just ...
14 years ago@jderrick
No this is not the case.... I again checked synthesis warnings and there is such kind of thing. I simply removed the logic as those signals are available from other module but this should not impact any thing as I simply adds two ports in compensation. All the ports except clock and reset are virtual ports
