10 years agosynchronous data in, synchronous data out issue
I have a single data rate edge-aligned (video) input signal consisting of the following lines: IMAGER_PCLK (the pixel clock) IMAGER_VSYNC (vertical sync pulse) IMAGER_HSYNC (horizontal sync pu...
10 years ago --- Quote Start --- What frequency is 'IMAGER_PCLK'? Assuming it's appropriate, I suggest you use a PLL, driven by 'IMAGER_PCLK', with two output clocks. The first you will use internally to the FPGA. This will latch the data in to and out of the FPGA. The phase of this clock will need to be appropriately aligned to the data on the incoming 'IMAGER_XXX' signals. The second clock output will drive out of the FPGA. This one you will shift in phase with respect to the data coming out on your latched 'ECU_XXX' signals, to suit the alignment requirements of the device receiving these signals. If the frequency of 'IMAGER_PCLK' is too low for this (which it may well be, depending on the VGA resolution you're using) then you'll have to use an independent, faster clock to latch the data at 90 degrees. You can then either regenerate 'ECU_PCLK' with logic or, as per your original design, simply drive it directly from 'IMAGER_PCLK'. Cheers, Alex --- Quote End --- Alex, Just wanna bring this to your attention again. Sorry for being pushy. Can you please reply on my last post? Thanks in advance. Kind regards, Richard.
