15 years agoSynchronization problem in PWM generation
I am using the DE2 board to generate a 20 kHz PWM signal. The duty ratio is constant 20%. The device is implemented by verilog. My method is to use DE2 board to generate a 20 kHz * 1000 = 20 MHz cloc...
15 years agoThank you very much!
It works, although I do not understand why....
