15 years agoSuggestions for simple link between two FPGAs?
I need to transfer about 100 bytes of data between two Cyclone IV GX FPGAs on two different PCBs. The PCBs are pretty close (less than 6 inches/15 cm) and the hardware hasn't been designed yet, but I...
15 years agoYes, clock skew and ESD are concerns, but there are impedance and frequency response controlled board to board interconnects that would make it a very sensible approach even without clock/data multiplexing and the possibility for skew. But usually at high enough rates one would just encode the data and clock and do a logic based CDR to avoid skew problems, or do some kind of synchronization / compensation anyway.
But for a mere 6" path @ 100 MHz you could have something that is every bit as good as a "on board" connection just by using the right board to board connectors with proper signal integrity / impedance / frequency response. For all I know you might just use a male/female PCB mount header or something to plug the boards together which would be better than even what one would consider a "backplane interconnect" to provide. Or FFC as is used with LCD LVDS or a couple SMB micro coax links or whatever. There are lots of good quanity short distance options that will not skew your signals by 50ns if you do use a clk and data distinct set @ 100Mhz. Anyway it doesn't matter much, if 10Mhz will work for you, use 10 or 20, less EMC, less timing worries, etc. --- Quote Start --- Two LVDS pairs (clock pair and data pair) is a sensible hardware solution, but at say 100MHz the interconnects would have to be carefully designed to meet clock skew, even over 6 inches. --- Quote End ---
