8 years agoStupid MAX10 question
Hi All, From reading the specs for the MAX10, I am assuming that the single-supply version of the chip requires all bank voltages be the same, and the dual-supply version allows up to two independ...
8 years agoHi Rysc,
Thanks for your reply. So if I understand, the dual-supply version gives you access to the core supply, whereas the single-supply version internally generate it. I see the timing specs are much better for the dual-supply version. Thanks for your insight. Scott
