13 years agoStruggling to program Spansion Flash memory with .jic file, Cyclone II
Hey all, I've been trying recently to program my project onto flash memory with no success so far. I was hoping someone here might be able to shed some light on the issue. Details: D...
13 years agoLook closer at your schematic, there is an EPCS4 configuration device on the left side of page 2. That is your configuration device.
There is an active serial (AS) configuration header that you can use to program the EPCS, or you can use SFL and the .jic file. Since you're new to this, just use the AS header directly, and then you can try SFL+.jic. Cheers, Dave
