13 years agoStruggling to program Spansion Flash memory with .jic file, Cyclone II
Hey all, I've been trying recently to program my project onto flash memory with no success so far. I was hoping someone here might be able to shed some light on the issue. Details: D...
13 years ago --- Quote Start --- I don't know your dev board: is that Spansion flash supposed to be used as a configuration device? Or it's rather intended only for storing user data. In the first case you need specific hw pin connections. --- Quote End --- Thanks for the reply Cris. I'm pretty sure it's meant to be used as a configuration device, since it seems to be the only Flash memory on the board. The only other memory I can see is some 256 Mb SDRAM (K4S561632H-TC(L)75) and some a 512KB Static RAM (IS61LV5128) I've attached the Dev kit schematic which might shed some light on the situation. Loading a program must be possible, because currently a demo program runs when the board is powered on. I'm somewhat of a newbie with FPGAs, so maybe there's another way to do this that I've missed?
