13 years agoStruggling to program Spansion Flash memory with .jic file, Cyclone II
Hey all, I've been trying recently to program my project onto flash memory with no success so far. I was hoping someone here might be able to shed some light on the issue. Details: D...
13 years agoYou can't use a jic file to program the Spansion flash.
First of all jic works with a serial device while S29AL032D has a parallel interface. Secondly, the jic must be generated for the specific configuration device which has to be programmed: then, if you generate a jic targeting a EPCS16, you can use only for this one. I don't know your dev board: is that Spansion flash supposed to be used as a configuration device? Or it's rather intended only for storing user data. In the first case you need specific hw pin connections.
