11 years agoStream data from USB device to FPGA
Hi, I have DE1-SoC dev board, which has the Cyclone V SoC device. The USB interface is connected with the HPS. I want to stream data from USB to FPGA, I tried to map the FPGA address to the u...
11 years agoDevice has a particular meaning in USB. It is something that normally connects to a USB host port on a PC/mac. For example keyboard, mouse, web-cam, printer etc. If this is what you have connected to HPS, you want ordinary host mode linux USB. If you are connecting HPS to a PC/mac USB host, then you need the setup I mention above. Find a Linux expert to help with USB aspects, then worry about the device driver for your FPGA component.
