13 years agoStratixI maximum input current
Hi, I'm looking for information about the absolute maximum input current a pin can handle before damage and the maximum current the PCI-clamp diodes can support. I'm using an EP1S60F1508 and I n...
13 years agoBut how much is the maximum input current for an input pin of the FPGA ? 25mA or 40mA?
And at pag 184 of stratix handbook there is this note: (3)Minimum DC input is –0.5 V. During transitions, the inputs may undershoot to –2.0 V for input currents less than 100 mA and periods shorter than 20 ns, or overshoot to the voltage shown in Table 4–9, based on input duty cycle for input currents less than 100 ma. The overshoot is dependent upon duty cycle of the signal. The DC case is equivalent to 100% duty cycle It means that a current of 100mA is acceptable for short period? I am assuming that the clamping voltage is 3.3 V+ 0.7 V = 4 V is this correct? Thank you in advance
