BJona
7 years agoStratix10MX, triple speed ethernet LVDS IO
Hi, I'm planning to use several triple speed ethernet Mac IPs but as far as i could see, you can't use Tile transceivers to do that. So i tried to compile my design with TSE (lvds io with integrated...
Deshi_Intel
7 years agoHi John,
1) For the fitter error
- As I suggested earlier, you can try check the resources from the passing 8 TSE design first
- Or if you need my help to debug further on 16 TSE design fitter error, then kindly pls send me your 16 TSE design QAR file so that I can review your design further to understand the root cause
2) For TSE IP connecting to XCVR channel
- As you can see from the attached TSE IP screenshot, only LVDS IO option is supported, not transceiver channel
- I am also curious why the S10 SOC example design mentioned TSE IP can be connected to transceiver channel. Can you share with me the link of the TSE example design then I can take a look into it ?
dlim
