10 years agoStratix V MLAB Byte Enable Issue
Hi, I am trying to implement a very small memory as a data buffer attached to an Avalon-MM interface. As the memory is only 16bytes, and I require that the output be unregistered, I am usi...
10 years agoNever mind. I gave up with altdpram and simply wrote my own module with an inferred RAM. Works perfectly
* I2C CSR Zero-Latency RAM
* This module provides inferred RAM logic with zero read latency
* and working byte enables. For some reason the altdpram instances
* are failing to use byte enables correctly.
module i2c_csr_ram_hw# (
parameter DATA_WIDTH = 32,
parameter BYTEEN_WIDTH = 4,
parameter ADDR_WIDTH = 2
input clock,
input writeAddress,
input writeByteEn,
input writeData,
input writeEn,
input readAddress,
output reg readData
localparam MEM_WORDS = 1 << ADDR_WIDTH;
localparam BYTE_WIDTH = DATA_WIDTH / BYTEEN_WIDTH;
//For simplicity the memory for each byte is instantiated separately.
genvar i;
generate for (i = 0; i < BYTEEN_WIDTH; i = i + 1) begin : ram_loop
//Offset into data word
localparam j = BYTE_WIDTH * i;
//Our memory for this byte
reg memory ;
//Write port
always @ (posedge clock) begin
if (writeByteEn && writeEn) begin
//When this byte is enabled and we are performing a write
memory <= writeData; //Store this byte from the writeData word.
end
end
//Read port with zero latency
always @ * begin
readData <= memory;
end
end endgenerate
endmodule
Just one more Altera IP core to add to my growing list of IP never to use again...
