13 years agoStratix V "CLKUSR"-Pin
Hi !
Maybe you can help me to get it right :) I found this in stratix 5 handbook: "The CLKUSR pin provides you with the flexibility to synchronize initialization of multiple devices or to delay initialization." So i can supply the "CLKUSR"-pin with a external clk-signal and this clk will be used to synchronize both fpga's? Where can i get more information about the "CLKUSR"-pin?? (working through some .pdf's but without finding much information at the moment) thanks in advance heiko2 Replies
Thanks for your help :)
--- Quote Start --- Hi ! So i can supply the "CLKUSR"-pin with a external clk-signal and this clk will be used to synchronize both fpga's? --- Quote End --- Yes, you can synchronize initialization of multiple FPGAs, which means that they will start working simultaneously. Additional info (albeit scarce) is provided by pin connection guidelines (http://www.altera.com/literature/dp/stratix-v/pcg-01011.pdf) PDF.
